Hondata - Idle Adjustment - Page 2 - S2KI Honda S2000 Forums
Notices
Old 07-29-2018, 06:23 AM
Chuck S's Avatar
As I read this again I can't find a problem. And I really don't like messing with ECU settings -- the reason I had Greg tune the car.
There's an old Anglo-Saxon expression for "Makes it seem like it's going to stall." It's called Does Not Stall. All engines react this way including my lawn mower when I engage the blades.
-- Chuck
Chuck S is offline
Old 07-29-2018, 09:51 AM
i've also reached out to greg however he hasn't responded yet.
astroboy84 is offline
Old 08-02-2018, 05:36 AM
I haven't performed the idle relearn procedure. I did however unhook the battery after it was flashed and drove it around.
Old 08-11-2018, 01:31 PM
Zer0ne's Avatar
Idle relearn procedure may fix your issue. Driving it around isn't the correct way to do it.
Zer0ne is offline
Old 08-14-2018, 06:16 AM
Snakecharmer's Avatar
This may help.....
In a previous post I have been trying to establish why my engine is stumbling when returning to idle. There have been many suggestions and I have stripped and checked everything from
Plugs to EGR Valve, including my IAC valve ( several times ) I thought I had almost cured the problem with a new air filter but today decided to strip my IAC valve once more...And very glad I did. There is much talk about cleaning the IAC valve to cure or prevent bad idle problems, however, I have not come across any information as to how to adjust the IAC valve...Yes, Adjust!
Today I have learned that in the same way the Throttle Position Sensor can be rotated, the IAC valve is also adjustable, in fact more so. Rotating the electric sensor when the engine isrunning has a major effect on idle and throttle response. I have "Tweek'd" my one for as best I can results but would like to know if there is a correct procedure? Anyone?
Snakecharmer is offline
Old 08-14-2018, 10:52 AM
flanders's Avatar
There is no separate IACV on the 06+ cars, idle is directly controlled by the throttle plate
flanders is online now
Old 08-22-2018, 06:16 PM
Can you point out where in the datalogs you're seeing the problem? After a quick scan, I only saw it where it dropped to 800RPM when off-throttle while moving. Is this the dip you're referring to?
If so, try this:
multiply the entire 'Throttle vs Airflow' table by 10% and see if that improves.
shind3 is offline
Old 08-23-2018, 12:35 AM
F1TwoThousand's Avatar
https://youtu.be/uOTY2JEGtrk
different ecu but it will help you see the bigger picture/philosophy
F1TwoThousand is offline
Old 09-18-2018, 11:31 PM
Did this issue ever get resolved? I'm having similar issues with my tune by Gernby. Sometimes rpm drops to ~700rpm when off-throttle while moving with AC on. The ECU would also throttle ~250rpm a second or so after returning to idle.
Also, which one is Throttle vs Airflow table? I only see "Throttle Index Calculation" and "Target Throttle Plate"
j2kei is offline
mikizzle
07-27-2011 02:33 PM
Nyther
02-01-2010 08:52 AM
S2KB00ST
11-09-2009 02:55 PM
dangerbates
02-05-2009 07:14 AM
OriginalFive
10-27-2005 07:03 PM
Quick Reply: Hondata - Idle Adjustment
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
