Infinity coolant temp calibration
Old Sep 4, 2015 | 11:45 AM
s2kfinesse's Avatar
Default Infinity coolant temp calibration
So my infinity is reading an extra 40*F for the coolant temp. What are you guys using for that table? The Honda sensor was selected.
I came across this thread, but that didn't solve it:
http://aemelectronics.com/?q=forum/h...ation-accurate
If someone has something, that would be greatly appreciated!!
Old Sep 9, 2015 | 04:51 AM
wadzii's Avatar
Banned
AEM is aware they screwed it up. The wizard used to be correct until the last update, someone fat-fingered something. It'll be corrected on the next update
The above table is correct
Old Sep 9, 2015 | 11:43 AM
s2kfinesse's Avatar
Interesting. Makes sense why it was very hard to find info on it then. Do you know when the update will happen? AEM was insistent upon it being a wiring issue n saying they hadn't seen that issue before. They wanted my Ecu and sensor sent to them for calibration.
Thanks again for your help!
Old Sep 18, 2015 | 04:49 PM
3XCstore AP1's Avatar
I had my firmware updated and calibrations done at C.A.T. (Church). My speedometer was off as well as my temp. Just had this done last week. Any updates on your end OP? Did you send your ECU in?
Old Sep 18, 2015 | 04:52 PM
wadzii's Avatar
Banned
The speedo is not driven by the ecu.. If the speed was wrong in the ecu that's a very quick fix in the software
Old Sep 20, 2015 | 06:52 AM
s2kfinesse's Avatar
My car hasn't moved, so can't tell about the speedometer.
Still having issues with the temp table. Pyng at AEM just sent me a table hat needs to be looked at. Super sick of this holding my car up, seen a few different tables now. Ecu hasn't been sent in, I will calibrate this myself before that happens.
Have you gotten your coolant readings sorted out?
Old Sep 20, 2015 | 07:50 AM
wadzii's Avatar
Banned
If the coolant temp is off by a few degrees it doesn't really make any difference in the tune.
Old Sep 20, 2015 | 08:04 AM
Chitoki's Avatar
Both were off after the latest firmware update? I know the coolant has been off for some time, but the new firmware?
Old Sep 20, 2015 | 08:39 AM
s2kfinesse's Avatar
Most definitely agree!
Mines still off by about 40. The one you sent was already the one loaded into the Ecu, which threw me off. Gotta sit down with this thing early this week to sort this out. AEM just sent me another table which looks like about 25* difference than the one earlier in this thread. Getting close to just calibrating it myself.
Old Sep 20, 2015 | 08:42 AM
s2kfinesse's Avatar
From Pyng at AEM Wednesday
C F Ohms
0 32 6205
10 50 3920
20 68 2454
30 86 1604
40 104 1072
50 122 738
60 140 535
70 158 387
80 176 284
90 194 210
100 212 159
110 230 121
120 248 95
130 266 75
140 284 60
