Infinity coolant temp calibration
So my infinity is reading an extra 40*F for the coolant temp. What are you guys using for that table? The Honda sensor was selected.
I came across this thread, but that didn't solve it: http://aemelectronics.com/?q=forum/h...ation-accurate If someone has something, that would be greatly appreciated!! |
https://lh3.googleusercontent.com/3-...o=w656-h159-no
AEM is aware they screwed it up. The wizard used to be correct until the last update, someone fat-fingered something. It'll be corrected on the next update The above table is correct |
Originally Posted by wadzii
(Post 23741581)
AEM is aware they screwed it up. The wizard used to be correct until the last update, someone fat-fingered something. It'll be corrected on the next update The above table is correct Interesting. Makes sense why it was very hard to find info on it then. Do you know when the update will happen? AEM was insistent upon it being a wiring issue n saying they hadn't seen that issue before. They wanted my Ecu and sensor sent to them for calibration. Thanks again for your help! |
I had my firmware updated and calibrations done at C.A.T. (Church). My speedometer was off as well as my temp. Just had this done last week. Any updates on your end OP? Did you send your ECU in?
The speedo is not driven by the ecu.. If the speed was wrong in the ecu that's a very quick fix in the software
Originally Posted by 3XCstore AP1
(Post 23751514)
Still having issues with the temp table. Pyng at AEM just sent me a table hat needs to be looked at. Super sick of this holding my car up, seen a few different tables now. Ecu hasn't been sent in, I will calibrate this myself before that happens. Have you gotten your coolant readings sorted out? |
If the coolant temp is off by a few degrees it doesn't really make any difference in the tune.
(Post 23751514)
(Post 23752450)
Mines still off by about 40. The one you sent was already the one loaded into the Ecu, which threw me off. Gotta sit down with this thing early this week to sort this out. AEM just sent me another table which looks like about 25* difference than the one earlier in this thread. Getting close to just calibrating it myself. |
From Pyng at AEM Wednesday
C F Ohms 0 32 6205 10 50 3920 20 68 2454 30 86 1604 40 104 1072 50 122 738 60 140 535 70 158 387 80 176 284 90 194 210 100 212 159 110 230 121 120 248 95 130 266 75 140 284 60 |
| All times are GMT -8. The time now is 04:11 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
