MSLabs MS3 Plug and Play ECU review
#72
s2kpotenxixe (09-18-2017)
#74
Here's mine just freshly off the tune. 85 degrees weather tune.
Baseline Spec:
-91 Octane
-T1R 70EM Ti exhaustt
-Ballade Sport 70mm HFC
-AEM Dry Filter over velocity stack
-70mm Skunk2 TB
-Stock ECU
Final Tune:
-Tune only, no other change. Extremely happy with the mid-range TQ extraction!
Baseline Spec:
-91 Octane
-70mm Skunk2 TB
-Stock ECU
Final Tune:
#75
Baseline Spec:
-91 Octane
-70mm Skunk2 TB
-Stock ECU
Final Tune:
Baseline Spec:
-91 Octane
-70mm Skunk2 TB
-Stock ECU
Final Tune:
#77
Baseline Spec:
-91 Octane
-70mm Skunk2 TB
-Stock ECU
Final Tune:
Baseline Spec:
-91 Octane
-70mm Skunk2 TB
-Stock ECU
Final Tune:
your Vtec is set at 5000rpm right? Stock torque curve is horrible :S
#78
Reverant, I tried to PM you but it says you wont take PMs. I want to buy but have one last question. Does this ecu accept KPRo cam and crank sensors or does the OEM sensors need to be re installed?
#79
