Noise from transmission help please.
Old 04-27-2017, 04:00 PM
hangman's Avatar
Default Noise from transmission help please.
Hi everyone I have a noise problem while idling from the transmission the only way it will go away is when I press in the clutch pedal. Can anyone please help me?
Old 04-27-2017, 10:07 PM
Singh_snisen's Avatar
Input shaft bearing is bad. I had the same issue.
Old 04-28-2017, 05:20 AM
hangman's Avatar
Thanks is it an easy fix?
Old 04-28-2017, 07:27 AM
Nope u have to breakdown ur entire transmission. It's easy to do if u have experience. Just time consuming. Btw it could be either input or output bearing. But if ur already in there I'd replace both. Cheap transmission fluid is the cause and for me it was Honda fluid the cause.
Old 04-29-2017, 06:12 AM
hangman's Avatar
[QUOTE=Singh_snisen;24197899]Nope u have to breakdown ur entire transmission. It's easy to do if u have experience. Just time consuming. Btw it could be either input or output bearing. But if ur already in there I'd replace both. Cheap transmission fluid is the cause and for me it was Honda fluid the cause.[/QUOTE
okay thanks
tom.tom
07-25-2017 09:21 PM
austincrx
02-01-2013 07:22 PM
ap1 George
San Diego S2000 Owners
08-29-2011 06:43 AM
DERF
08-16-2006 03:50 PM
Fredrick
05-16-2003 02:17 AM
Quick Reply: Noise from transmission help please.
