Safe to run old tune from previous car on new car? - S2KI Honda S2000 Forums
Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Engine Management
Reload this Page >
Notices
Old 09-21-2018, 01:35 PM
Default Safe to run old tune from previous car on new car?
When I had my CR I had a custom flashpro tune done by Bisimoto, mods included: gutted OEM intake, 3" HFC, and 3" Single cat back exhaust. Since then I've sold the CR and picked up another AP2 that has very similar mods: gutted OEM intake, 3" test pipe, and 3" dual cat back. Will I be okay running and tracking the car with that existing tune on this new car?
CR295 is offline
Old 09-21-2018, 03:15 PM
EOE
EOE's Avatar
I wouldn't until i put it on a dyno and have a tuner confirm all is well. Even though motors are physically identical, each has it's own character and needs it's own tune usually. The only way I'd feel safe driving it hard is if the previous tuner told you that his ignition timing was very conservative for safety and still I would need a dyno session to be sure that it's not knocking/detonating with your new motor/car.
EOE is offline
Old 09-21-2018, 03:39 PM
Originally Posted by EOE View Post
I wouldn't until i put it on a dyno and have a tuner confirm all is well. Even though motors are identical, each has it's own character and needs it's own tune usually. The only way I'd feel safe driving it hard is if the previous tuner told you that his ignition timing was very conservative for safety and still I would need a dyno session to be sure that it's not knocking/detonating with your new motor/car.
Ok thank you for the reply. Just got ahold of Bisi and he said not to track the car and to have a custom tune done.
CR295 is offline
Old 09-22-2018, 07:58 AM
Chuck S's Avatar
The "old" tune has most of the work done for the new car. Should be a safe starting point for your tuner and perhaps shorten the process. What is the VTEC rpm engagement? (Just curious.)
-- Chuck
Chuck S is offline
Old 09-24-2018, 06:30 PM
-- Chuck
I think it would engage at 4200 rpm.
CR295 is offline
siklilplaya
02-21-2017 01:18 AM
s2konroids
04-05-2013 02:57 PM
JayC07
12-07-2012 04:47 PM
civic_redline
16
11-18-2012 01:39 AM
OldDogmeat
07-11-2008 02:42 PM
Quick Reply: Safe to run old tune from previous car on new car?
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
