1/4 mile update
My mods are the inline pro kit with 3mm HG, i did get the ball bearing upgraded turbo. i have no catslytic converter i am straigh exhaust all the way back. lol. i have the skunk2 3in dual exhaust. AEM for my computer. Ported head. thats it for the mods
No wheels, the drag radials took care of that
Originally Posted by btstone84,Mar 3 2008, 12:09 PM
i wanted to be in the 11s but it feels like the car is almost at it limits, i think a 12.0 may be possible but not much more without a little more modification
Originally Posted by Spec_Ops2087,Mar 4 2008, 11:07 AM
What kind of power are you making? If your making in the 400 range, 11's should be possible especially with DRs
what happened to the car at the end of the day? You were smoking something fierce from under the hood and then when you went to stage the final time you ended up turning around and going back to the trailer.
Also, what was going on during your first couple passes of the day? Sounded like you were having some spark blowout issues or something.
Did you trap any higher than 117 on Sunday? At that kind of speed it sounds like you were making a little under 400 at the wheels that day.
the popping was i didnt let the car warm up enough the first time and then i think i had my boost turned up to high for my injectors. i can only run 19psi b4 my injectors basically "run out". but my psi changes with the weather temp so i have to play with the setting each time to figure out the right setting. so those first couple of passes my engine was not getting gas after like 7K rpm. its an experiment with this being my first import/ turbo car. but a fun one. I did trap a 121 but that was a 12.6 pass
