2017 New Jersey Inspection
Old 11-20-2017, 10:09 AM
minubaba's Avatar
Default 2017 New Jersey Inspection
Hi there - I just moved from PA to NJ. The inspection process seems smooth here for my other car (totally stock) but I did notice the below when I did an ODB2 scan on my boosted s2k. Will I fail because Misfire, Fuel System, Evap, and EGR are not showing Complete? I am running HONDATA KPRO.
I do not run Cats, but have a spare downpipe with cat that I can throw on to pass visual...
Old 11-20-2017, 11:25 AM
Soul Coughing's Avatar
The answer is: It depends. Is the Hondata using the Acura RDX ECU? When it's plugged into their system, it will come up as that if they're looking. Depending on the year, the ECU will show a VIN, which they will then compare to the VIN on the door jam. If they're different, they will have an issue. If they check all the readiness codes, you will fail for the EVAP. However, I have a EVAP simulator (and didn't have readiness) and they passed me with flying colors, although, I swapped a cat on and just kept the supercharger on with stock ECU so it looked completely stock. You can give it a shot and see, and let everyone know! Worst case you pay for a private inspection that are usually more lenient.
Old 11-20-2017, 12:56 PM
minubaba's Avatar
Not sure I follow... you have a EVAP Simulator, but it did not work? But you still passed?
I do not have an OEM ECU... if I did, wouldn't installing on my highly modified engine cause problems? Probably throw a CEL and cause me to fail my inspection anyway?
Old 11-20-2017, 01:13 PM
Chuck S's Avatar
Received 1,132 Likes on 995 Posts
Let us know what happens.
The NJ inspection includes a smog/emissions test so I'd be surprised if you can pass without a catalytic converter.
-- Chuck
Old 11-20-2017, 01:53 PM
RuRoUni_SS's Avatar
I just recently did an inspection on my STi. You probably won't pass the visual as there are cameras when your drive over to the inspection station that views your undercarriage to see if you have CATs. Let us know what happens. Not sure where in NJ you are located, but if you are located in South Jersey, I would go to the inspection station located in southhampton. Super quick, very few people go there so you are almost in and out.
Old 11-20-2017, 07:38 PM
minubaba's Avatar
I have a catted downpipe. I can swap it before inspection.
All I have to do is get the evap to turn on. Found out our cars have NO egr...
Old 11-21-2017, 08:40 AM
The EVAP simulator worked in the sense that it did not throw a code, but when checking the readiness codes, it says it is still pending. It is still pending a couple years after i installed it.
You can run a stock ECU with stock injectors and just prevent the ECU from seeing boost from the turbo. If you can pass the visual test, and the car doesn't throw any codes, then yes, you could use the stock ecu to get inspection done. I don't know how modified your motor is, but if you're mechanically inclined, you can do it too. I have done that when my car was turbo, and I do it now when its supercharged.
8b8bbbb
02-09-2018 10:15 AM
kingart
06-23-2014 08:22 AM
fenixv8
04-04-2011 09:13 AM
togueep3
10-04-2007 05:22 PM
Black Moon
04-18-2002 04:03 PM
Quick Reply: 2017 New Jersey Inspection
