2mm vs 3mm headgasket
just wondering I hear that the most boost you an run on 93 octane with the 3mm head gasket is about 18lbs (correct?)
what the most boost you can run with the 2mm head gasket? power difference?
just trying to figure out what would be more siutable for a *healthy* street car.
thanks alot
thanks alot
I talked to Cometic and they offer a .074" (1.8796mm) and .120" (3.048mm). Cost was approx $106 and $132 respectively (plus s&h I assume). Does anybody have the mathematical knowledge to calculate the what those compression ratios would be? Thanks!!
