3 bar map sensor
Old Aug 22, 2008 | 11:08 AM
J'sBlackAP1's Avatar
Very nice placement. I will be putting mine there as well.
Old Aug 22, 2008 | 01:43 PM
AusS2000's Avatar
Guys, he's talking about the GM not the AEM.
Old Aug 23, 2008 | 05:40 AM
passmans2kny's Avatar
couldnt u mount it in the same place though?
Old Aug 23, 2008 | 09:36 AM
2big4aS2000's Avatar
i mount them on the coupler bolt that is on the TB. drill out the round hole a little bit, slide over the t bolt clamp on TB and add another nut - done. wires reach, and short hose to fitting i posted b4 ontop of TB.
Old Aug 23, 2008 | 09:46 AM
got a pic 2big?
Old Aug 23, 2008 | 04:15 PM
jefferyg32's Avatar
I mount mine on the throttle body where the stock on is. Use this one and you'll have no issues. No wiring cutting and still works like factory when not in boost. Its what im using. Just my .02.
http://scienceofspeed.com/products/engine_...eed/MAP_Sensor/
Old Aug 23, 2008 | 06:26 PM
jwa4378's Avatar
jefferyg32 - Is that one by SOS recognized by AEM, or do the parameters need to be setup?
John
Old Aug 23, 2008 | 06:32 PM
9kFever's Avatar
The hondata map sensor (4 bar?) is absolutely plug and play.
Old Aug 24, 2008 | 02:19 PM
killabee's Avatar
yeah those are all good options but i have a gm sensor. does anyone have pics of there install and how they did it?
Old Aug 24, 2008 | 02:28 PM
AusS2000's Avatar
The GM is a plastic rectangle with a barb sticking out the underside. Very different to the AEM.
I made an aluminium bracket and mounted one up front near the throttle body with the vacuum line connected to the intake manifold.
