S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   4 Bar Map (https://www.s2ki.com/forums/s2000-forced-induction-142/4-bar-map-613362/)
H.A.R.T B18C1EG6 Jul 14, 2008 02:58 PM
Originally Posted by chairmnofthboard,Jul 14 2008, 11:52 AM
I like the clean factory look of it.
the reason why i purchased one also...
AusS2000 Jul 14, 2008 02:58 PM
Would be good if someone would post the cal values for the Omni/Hondata MAP sensors.
A few months back every body was talking about them but this the first time I've heard of one being successfully installed.
Being stock shape and fit but supporting a wider range is a great bonus to FI users.
bigpurp Jul 15, 2008 09:17 AM
Originally Posted by chairmnofthboard,Jul 14 2008, 10:52 AM
Has anyone tried this 4 bard map yet? Will the ems be able to use it?
4 bar map
Good info in here. :thumbup:
You should edit the title of the thread to add "Hondata/Omni" so it will come up in future searches. ;)
OmnipowerUSA Jul 16, 2008 03:19 PM
Here are some scalar and offset numbers as well as a voltage vs pressure table for people using this sensor.
Scalar: 838
Offset: 31
Volts/kPa 0.32/30 0.563/50 0.926/80 1.168/100 1.895/160 2.621/220 3.347/280 4.073/340 4.799/400
For anyone using Motec i have those cals as well . you can email me at Omnimanlsr@aol.com thanks
AusS2000 Jul 16, 2008 03:41 PM
Nice :thumbup:
EriS2k Jul 16, 2008 06:19 PM
Scalar: 838
Offset: 31
Great!
Nice Info! :thumbup: :thumbup:
OmnipowerUSA Jul 27, 2008 02:57 PM
Just a heads up for people, The newest version of AEM software will have options for this 4 bar sensor to make life a little easier.
also for people currently using this 4 bar here is a voltage vs pressure conversion formula. this will allow you to build your own calibration table if needed depending on what engine management your using.
4 bar
Scalar 838
Offset 31
Voltage to pressure (KPA) conversion
P= pressure in KPA 4 bar = 400 KPA
Voltage out/signal = 5 X (.002421 X P - .00842)
Atmosphere equals 1 bar or 100 KPA = 5 X (.002421 X 100 - .00842) = 1.168 volts @ 1 bar or 100 KPA
1 bar=100 Kpa=14.5 psi= 1000 millibar
last thing if your at a non sea level elevation such as a guy in denver (5000+ feet above sea level) your key on engine off voltage wont be 1 bar because of the elevation. but your engine management will acount for that so its not something to be alarmed about.
AusS2000 Jul 27, 2008 04:54 PM
Thanks Omni. You should consider becoming a sponsor on S2ki.
9kFever Aug 26, 2008 04:52 PM
I am using the Hondata 4 bar and it works great. CHP just inspected my engine bay and didnt notice a thing
killabee Aug 26, 2008 05:55 PM
This is good info
© 2026 MH Sub I, LLC dba Internet Brands
