Andy's BB 2008 CR Turbo Build
Follow me on iG: boost2k
UPDATE 01/12/2023 I'll continue to update the "parts list" on the first post with current parts so viewers can reference what parts I have had and currently have on my build . . . Hi guys, Just want to introduce my project to you guys to get some helpful feedback along my build. I've been collecting parts for years, actually since two Hondas ago to be exact to go boost. My goal is to hit around 500hp on E85. I also want to buff up my head with springs and retainers but not sure if that's necessarily needed at this time. Anyway, I've finally got around to tearing the CR down this weekend and am committing to this build! Wish me luck! Some photos of when i first got her: https://cimg5.ibsrv.net/gimg/www.s2k...7ddc075ea3.jpg https://cimg9.ibsrv.net/gimg/www.s2k...2fa0d681c2.jpg OG RG1s for a little while https://cimg5.ibsrv.net/gimg/www.s2k...5efa683638.jpg Then came the 17x10 ce28n https://cimg6.ibsrv.net/gimg/www.s2k...b420d54fde.jpg Alignment at vodie's https://cimg8.ibsrv.net/gimg/www.s2k...7c344c65f1.jpg Currently, my build consists of: ENGINE/TRANS Stock 2008 unopened f22c 65xxxmiles now 80xxxmiles Stock transmission Stock differential Supertech dual valvesprings 95lbs and titanium retainers Spoon magnetic engine and trans bolts Fluidampr crank pulley damper Balladesports TCT Balladesports bolt-in oil pan baffle Balladesports vented oil cap NGK Iridium 8 spark plugs OEM K-series coilpacks Vibratechnics HON200M motor mounts Alloycraft heater bracket Timing chain cover -10AN oil drain Honda OEM friction disk AP1 resurfaced flywheel Exedy hyper twin clutch Exedium differential collars Koyo hypercore radiator 12" Spal extreme fan with custom shroud TURBO Garrett T3/ Import Auto Pros sidewinder manifold and 3" downpipe, open dump Tial MVR wastegate Synapse synchronic bov Precision 600hp intercooler PFAB 2.5" aluminum intercooler piping Schmuckbuilt oil catch can and coolant reservoir Challenge 3" Ta-R exhaust Mac 3 port boost solenoid Hondata Flashpro Hondata 4 bar map sensor FUEL Five-O 2200cc Blackops E85 Bosch injectors SOS fuel return system SOS fuel pump wiring kit SOS modified AEM fuel rail Walbro 450 e85 fuel pump AEM fuel pressure regulator GM Continental flex fuel sensor Digital to analog signal converter SUSPENSION Swift Spec R springs on factory CR struts MISC Defi BF boost gauge and controller HKS turbo timer Backyard Special low seat rail Karbon Haus Spoon style CF hood JDP single exit CF diffuser Downforce CF side diffusers Shout outs: Pang at PFabrications All the guys at Science of Speed Nate at Balladesports Lorenzo and David at Import Auto Pros James and Lawrence at Signature Autobody Kenneth at Funfzehn Automotive Speedfactory Moses @nalgas_de_fierro I literally just started the tear down this weekend and only got around to fitting the intercooler. I'll try to be as detailed as I can with each step so others may find this thread helpful if they're in the same situation as me. Then again, I'm usually pretty good at taking pictures and documenting stuff at the start and tend to forget to take pictures towards the end...hopefully that doesn't happen. Anyway, on with the build and pictures! I cut and smoothed the plastic guards with a dremel to make room for the intercooler piping. Driver's side: https://cimg3.ibsrv.net/gimg/www.s2k...22068e7830.jpg Passenger's side: https://cimg4.ibsrv.net/gimg/www.s2k...9f9a7265e1.jpg Once clearance for the piping was good, I used the dremel to cut away at the support beams to make room for the precision intercooler (its all hacked up, gonna clean it up later when its all fitting nicely). Passenger's side: https://cimg8.ibsrv.net/gimg/www.s2k...528bb6f082.jpg Driver's side: https://cimg1.ibsrv.net/gimg/www.s2k...40bd214dab.jpg As you can see, I started to make a bracket out of 1.5"x1.5"x6" aluminum L bracket to use as an anchor to mount the intercooler. The precision 600hp intercooler has a threaded hole on each endtank. It also had these aluminum extensions that I cut off to get the intercooler up higher closer to the crossbar about 1/4" more, shown below: https://cimg3.ibsrv.net/gimg/www.s2k...95f5041fb8.jpg Then I mocked up the pfab manifold, turbo, and downpipe. I ended up thrashing the exhaust manifold studs taking them out. Gonna have to buy some new ones :/ It all fits very nicely. Only thing is the elbow for the wastegate sits on the hard brake line which I'll have to bend the line out and around the elbow. Just wondering how I should go about doing this so that I don't put a kink in the line or cause it to vibrate against the chassis somewhere (if anyone has pointers here, please share, I was planning on just using some pliers with shop towels to prevent any scratches??). https://cimg7.ibsrv.net/gimg/www.s2k...d8b4690700.jpg Downpipe: https://cimg2.ibsrv.net/gimg/www.s2k...4d158d84cc.jpg Hard brake line issue: https://cimg8.ibsrv.net/gimg/www.s2k...a6719a4f79.jpg I'll end up putting a 3" flexpipe somewhere between the end of the downpipe and testpipe. BATTERY RELOCATION I also relocated my battery and fusebox some time ago referring to multiple diy threads here on s2ki. The relo was pretty easy and straight forward for anyone tackling this too. I took a couple pictures to show how I did mine. https://cimg7.ibsrv.net/gimg/www.s2k...349adca5bf.jpg I relocated my battery to the trunk with 0gauge welding wire and gold terminals from O'Reilly's autostore. I had to use a step bit to drill a hole in the firewall to feed the wire through. From there I used a distribution block to wire it up to the factory fuses. I grounded the battery to a bolt behind the passenger seat and it seems to hold well with no electrical problems...yet. Hopefully its a good spot, I probably should have sanded the area down a bit but it hasn't given me grief yet. I also used a Scorpion battery kill switch nearest the battery for the power line. It's a cheaply constructed piece but its doing the job. I wrapped it with an old neoprene knee brace that I had so stuff in the trunk don't accidentally hit it. It's kind of half-assed since I couldn't find good places at the time to mount everything. But I recently saw another member mount the battery with factory hardware in the spare tire section, looks so much cleaner. I might have to copy him and place my battery there. As for the fusebox, I ordered a second bracket from Honda pictured below and it worked out perfectly with how I mounted the fusebox turned to the side. https://cimg0.ibsrv.net/gimg/www.s2k...053369abab.jpg Well this is where I'm ending the build tonight. Dropping off my spare oil pan with my dude at Import Auto Pros to get the bung welded up. I ordered some grey permatex for the oil pan sealant (is this good stuff??) Hopefully I'll have some time tomorrow to finish up mounting the intercooler. I want to be able to run the stock grill to be a little more stealth on the road. I'll take pictures of how that goes. Thanks for reading, and if anyone has any pointers for me drop a line, good or bad. I'll definitely have questions for you guys throughout this thing so help me when I ask haha. |
BTW, here's a picture of how the car looks right now :hello:
https://cimg3.ibsrv.net/gimg/www.s2k...7899c6a172.jpg |
First dyno
435whp and 331wtq |
https://cimg7.ibsrv.net/gimg/www.s2k...a132a0ae2e.jpg
New dyno on 6/26/17 @18psi. Tuner is Dave @importautopros 499whp/367wtq Night runs with a few friends A few runs against my buddy with a 511whp evo10 F80 M3 Vortech SC S2000 and Tesla P100D |
the brake line just unclip it and bend away slowly and careful away from the manifold. I have same manifold but on a 66mm turbo. 6096511866 text me any questions-Luis
Originally Posted by sdosmil77
(Post 24110967)
Looks good. you should be able to make your power on that turbo . about your brake line. I would just buy some heat cloths and wrap them. I did the same on my and it's been fine. no brake line damage. here mine if you want to look threw it.
https://www.s2ki.com/forums/s2000-fo...-dyno-1163803/ |
I would use studs with nuts/lock washer on your turbo manifold so your bolt don't back out on your turbo. also the srt4 arp manifold exhaust manifold studs with some loctite works good. I haven't have them back out on me and also the studs are longer than the s2k studs so you have a little bit more grip. I had bad boost creep on the tial 44mm mv-r wastegate brand new. the precision 46mm work for me. Your ap2 retainer will be good for your power level. No need to upgrade them. just some stuff i ran into on my built that could help you out.
Tap your timing chain cover instead of your oil pan. |
Thanks Hershey. i just ordered these titanium studs from speedfactory 35% off black friday deal, cant beat that!
https://www.speedfactoryracing.net/s...stud-kit-14015 i decided not to ceramic coat the pieces thanks to a member who warned me it would void the warranty. Man, this is what a car forum is supposed to be like :) Next comes finishing up making the brackets and mounting the intercooler. ill keep updating the thread |
Had my battery in the exact same spot! But don't forget to put some sort of rubber insulator caps on your terminals, I learned the hard way. Had a few occasions when I took a sharp right turn and my battery leaned and the terminals arched against the metal trunk hinge and my car completely shut off :thumbdn: Can't wait to see your finished project!
