Andy's CR PFAB Turbo Build...so it begins.
#231
I have Flashpros for sale!! PM me if anyones interested.
#232
[left]
sounds like the hondata flex fuel is better suited for supercharged setups
yea its the same in flashpro. The problem is there is no way to increase or decrease boost with varying levels of ethanol content. Its one psi all the way. As much as i dont want to, im switching ems to aem. I need the flex fuel capability since los angeles hardly has any e stations.
#235
Here's a dyno graph of a run on 91 pump (but oddly showed 45% ethanol content [not sure if this was an accurate reading at the time]), made 431whp at around 12psi. The e85 run ended up at 485whp at 15-16psi. These were all with the new five-o 2200cc injectors and walbro450 pump. On the new manifold the same wastegate spring maxed out at a lower psi level than on the pfab manifold (18psi). Time to put in a 10lb spring then retune for more boost. Planning on going to aem ems2 to run a true flex fuel tune as well. I swear this project will never "end" haha. I always want more. Might have to go rear end after all this is dialed in. This small 58mm jb turbo produces a great torque/hp curve though.
#237
Weren't u already on 499whp before on same ECU and e85? Why isn't it working this time around? I'm thinking about increasing my psi for more power with the same 1600 and fbm340 as well. I've seen lht performance push 25psi on gtx3076 on e85 no prob closer to 600whp
I wouldn't want to change turbo and sacrifice spool.
#238
Okay running into all kinds of hurdles. So the aem series 2 requires a harness for the 06up ap2 which we dont have...so back to the drawing boards. Might just have to run a separate 91 and e85 map on the flashpro, altho not ideal, to get me by when in a pinch. Just gonna have to save up for the infinity or something...
Edit, he had a harness. We'll prob be adding this later to run flex but for now we just retuned on flashpro and made 515whp.
Mijae007 (05-15-2018)
#240
