anyone has problems boosting past 7k on 1st gear?
Like title says. I've noticed on cool nights on 1st gear my S will boost hard and pulls all the way to 8k rpm but on hot days i'll stop at 7k rpm. Rpm will go to 8k but it wont pull as hard. 2nd 3rd 4th ... are always pulling hard to 6th gear.
weird...
weird...
How are you even getting traction in 1st...or 2nd for that matter? If youre hitting desired psi in all other gears im sure youre fine. But im all squirley in lower gears, even 3rd will break loose sometimes.
if its hot out your ems might be lowering boost based on iat compensation tables in your map. Maybe check there if youre experiencing lower peak boost in hot weather
It might be something with my tune also from Erik's racing at 7psi. Then I had it retuned up to 11.5 psi in Bakersfield at vlspeed. The tuner from vlspeed said that he didn't change anything on the 7psi tune. He just added to it.. I do need to get another exhaust tho. I wanna go straight pipe and 3 inch dual exhaust. My invidia q300 sounds bad past 7k rpm.....
Dang that's a lot of power. What's your setup? I think my 70mm hfc and invidia q300 is holding my exhaust flow back. When it hits like 5k rpm there's a loud noise coming from the mufflers... I'm getting a new 3 inch hks single and 3 inch test pipe from ROCKSTAR garage
