AP1 Vortech V2 kit on MY07
Here's the situation, I'm looking to buy an Vortech SC but it's from an AP1. It comes with complete including fuel pump and injectors. A small and a large pulley, unsure of sizes at the moment. Was told he made 300ish on the larger pulley and 400 on the smaller.
1. So I know I can't use his injectors, I'll need new injectors. Recommendations?
2. Do I need to worry about the 5th injector that comes with AP2 kits? Should I source one?
3. Will I need a map sensor?
4. What am I missing? I will be using a flashpro.
I searched and read through a few threads, but I didn't find the answer.
ID1000 with 06+ plug an play clips
no need for 5th injector
OEM map unless pushing higher hp (12+psi, maybe someone else can confirm the OEM limitation)
Flash pro will work
Flash pro will work
kaissi
04-10-2012 11:40 AM
