Best BOV/BPV replacement for CT-E SC
Old Feb 8, 2017 | 10:16 PM
Spaceman2345's Avatar
Default Best BOV/BPV replacement for CT-E SC
Has anyone successfully replaced their CT-E SC/SOS/Vortech kit's Bosch BPV?
If so, list your SC and which BOV/BPV worked for you.
Old Feb 9, 2017 | 01:36 AM
MARK AUS S2K's Avatar
Hey mate why don't you weld on the greddy flange which allows you to use a large TIAL QRJ and recirulate it?
Just info from what I've read on here.
Old Feb 9, 2017 | 09:27 AM
CoolGuy094's Avatar
If you have a CTE kit, you may get lucky and find one of the adapters floating around in the FS section that you can bolt on to the aftercooler and then attach a Tial BOV like the Q, QR, or QRJ. I ran a Turbosmart Kompact Dual for a while, then switched to a Tial Q with said adapter (too loud for me), then switched to the Tial QR (perfect), then eventually added the Bosch BPV back onto the 3/4" air pump port to run a dual BPV setup.
Old Feb 9, 2017 | 09:29 AM
CoolGuy094's Avatar
Did you end up putting a N1500 in your car? Did you use the QRJ with it successfully? I would have thought the QRJ wouldn't vent the N1500 enough.
Old Feb 9, 2017 | 10:17 AM
Dang, i thought it was a simple plug and play I'll diffidently look for that adapter.
Old Feb 9, 2017 | 10:54 AM
E4RTH WORM JIM's Avatar
Tial FTW
Old Feb 9, 2017 | 11:29 AM
CoolGuy094's Avatar
You can buy the QRJ with a 1" diameter inlet port instead of the standard v-band flange. That will allow you to direct-connect it to the 1" diameter outlet port that bolts onto the CTE aftercooler. But you'll probably need to find a 90 degree 1" elbow because I don't think you'll have the room to come straight off the port into the QRJ.
TiAL Sport - TiAL QRJ
The 1" hose fitting for the inlet is part number 004812.
Edit - Just remember, as far as venting capabilities go, Q > QR > QRJ. The QRJ is actually a 38.5mm (1.5") valve versus the Q and QR's 50mm valve. If you're working with higher SC pressures you may want to consider using the Bosch BPV on the air pump port in a dual setup.
Old Feb 9, 2017 | 05:20 PM
volcomboy390's Avatar
I have one of the adapter and a qrj but I haven't been able to use it... I have the new koyo rad and mishi fan shroud and there is jug not enough room... I'm using the 1.5 tube adapter and had a almost 1.5 adapter made that bolts to the after cooler, then used a 145' rubber elbow (or 135) to connect it. Not ideal but it flows more air then it did...
Old Feb 9, 2017 | 05:51 PM
JUSTINTHECOASTIE's Avatar
Yes with a Tial Q, see before and after pics in my thread
Old Feb 10, 2017 | 10:49 AM
I also was told that the APR R1 Diverter Valve that is used for the VW/Audi 1.8T works as well. Any experience/info on this...
In respect to the Tial Q, i was watching some YouTube clips and i must say that BOV sounds NICE!
