Best upgrade from walbro 450?
I'm looking at options for upgrading the fuel system so I make sure I don't run out of pump on the dyno. Currently running a rewired 450
I'm on E85 will be with ID2000s shooting for 700hp.
This is on an 05 so I have a return system. Im trying to keep this as simple as possible.
I was thinking, Is it possible or had anyone here ran a stock fuel hanger and ran an external bosch 044 to the stock fuel rail?
A single wallbro 450 should support 700whp on e85. I have made 630whp with it before on e85. I know there were a few guys with the 450 on Honda tech making over 700whp on E85 with it.
some say it supports 700 and others say they ran out of pump in the 600s. There is no reason to cut it close as I don't want to take any chances. Dyno time is a lot more expensive.
safe 600 Once over 650 it depends on injectors and pressure your trying to achieve. I was knocking on 700 when mine started lossing pressure at higher duty cycles with my 2200s.... it actually did better on the 1650s because it did not have to work as hard... but i quickly maxed the 1650s out.
Now dual staged 450s and 2200s.... got all the fuel in the world hoping good for 950-1000
