Best water hoses for a gtx3076
I have been running water cooled garrett turbos for many many years in all my cars and for the water cooling you must run a hard line. This really is the only way to go. I use to run rubber lines off the center section and the may last a few months before they crack and break. Then i switch to stanless steel an lines and they were way better but they too would leak at the an fitting after maybe a year or 2. This is with the line wrapped in heat sleeves. worst of all with stainless line you cannot see or tell the condition of the lines. I now run evo8 hard lines off the center section pointing torwards the cold section of the turbo then i just use standard rubber lines to connect to the evo8 hard lines. This setup will be good for 100,000+ miles with out issues. There is a reason why all factory turbo cars run hard water lines off the turbo.
Here is my ptunning kit with a garrett gtx3076r with evo 8 hardline for the water.
This similar to what your running? Also it should be the same for the gt series and gtx series right?
Finally got my SS water lines for the gtx3076 installed. I also upgraded to a bigger air filter as well
Heres a little clip.
https://www.youtube.com/watch?v=DRfjhESmvi8
I searched on Amazon as forcebird recommended
Banjo Bolt kit M14x1.5 mm to -4AN Garrett GT28R GT30R GT35R T28 Turbo Coolant
You have a Garret turbo as well?
next step. I need to get a dual 3 inch exhaust and a test pipe getting ready for e85. Don't know which one to get.
next step. I need to get a dual 3 inch exhaust and a test pipe getting ready for e85. Don't know owhich one to get.
https://www.summitracing.com/parts/bor-40359/overview/
and a vibrant ultra quiet resonator
https://www.summitracing.com/parts/vpe-1142
There hasnt been anyone that has done the borlas... ive seen some magnaflows tho...
Exactly stainless line to an adapter to a regular line. It was $55 to get 2 lines in a packet. They weren't too hard to get installed. I want dual exhaust because I like the way they look and I have the ap2 bumper. Im thinking about going dual borla pro xs downpipe 3 in all the way
