Bigger battery for forced induction?
Don't know what's going on. I wonder if I need a bigger battery or I need to test to make sure my alternator is even charging my batteries. I have a small oddyssey 680 battery engine bay (these are junk) btw linked up to the stock s2000 battery which is relocated to the trunk and I'm having trouble starting the car in the mornings. I'm running 91 and e85 together.
I'm thinking about getting the battery load test done and having my altanator checked out. Any other suggestions? Maybe get a bigger battery with better cca? Maybe just run full 91 until it gets warmer in the summer months April till November? |
Get a standard size battery. You relocated to the trunk right? Make sure its an agm dry cell battery so you dont have poisonous acid spill all over your interior lol.
I had this issue with a Optima red top when I relocated to the trunk. I had to add multiple grounding locations to fix it, one 2 gauge and two 8 gauge. Doesn't help that there really isn't a good ground location in the trunk. I used the mounting point for the shock on mine.
change your negative battery cable. i searched for weeks tryin to figure out WTF my electrical issue was. Battery relocated to trunk. i checked all fuses, replaced entire power wire etc. as soon as i swapped the neg cable, boom, all power no issues.
Originally Posted by Charper732
(Post 24427980)
...I had to add multiple grounding locations to fix it, one 2 gauge and two 8 gauge. Doesn't help that there really isn't a good ground location in the trunk. I used the mounting point for the shock on mine.
Originally Posted by LostMarine
(Post 24428111)
Its not the battery its the relocation that is killing you. When you relocate a battery to the trunk most use too small of wire running to the front and the wire quality is usually crap which only exaggerates the problem now that you have added a ton of length. Next thing is as others have stated above that grounding to several points in the trunk is a must.
Originally Posted by Mijae007
(Post 24428274)
If thats the case, make sure to sand down any paint at the grounding point to ensure a good ground. I used a bolt just behind the passenger side seat with 0ga welding cable (same as my positive) with no issues. Used a yellowtop optima.
Curious as to why folks relocate the battery to the rear and run more heavy wire, on a car that is already distributed 49/51% to begin with? So making it more rear heavy and adding more weight in cables? Personally, I would just run the battery in the stock location, or is this to make room under the hood for something else?
Originally Posted by engifineer
(Post 24428460)
Ah, makes sense. I thought it had to be mostly for room on the FI side. I guess I can see the engine bay cleanup .... but I look at the S as a function >>>>> form car.... so dressing the engine bay up didnt even come to mind :P
