Block off plates
#23
SAIVs don't 'read' anything.
Only possibility is that the vacuum line (pressure under boost) to it was leaking. The vacuum line runs from the intake manifold, through an electronically controlled solenoid (originally mounted on OEM airbox but moved to the vacuum canister and mounted under the SC with the Comptech kit) and then to the SAI Valve.
But all of this was superflous after you went AEM so whether or not you have a SAIV in place you can remove this hose and use the manifold connection for something else (mine is connected to my boost sensor) or just cap it.
#24
Originally Posted by s2kadrenalin,Aug 24 2010, 12:46 AM
^ Site Sponsor, S2KPuddyMod & InlinePro (used to, possibly still do??? for $30) sell them.
I blocked mine off too as the Idler Control Valve / Secondary Air Injection Valve leaked boost above 4 psi.
Fixed the problem with the block off plate and found an extra 50whp.
#25
#26
Originally Posted by s2kadrenalin,Aug 24 2010, 04:53 AM
Then why did my SAIV read boost on a boost leakdown test?
The item I've removed is definately the SAIV.
block off plate makes things look nicer under the hood. its a cluster as it is on that side of the motor.
#29
Originally Posted by o'malley_808,Aug 25 2010, 12:10 AM
Wouldnt doubt if his was leaking cause mine was too! Thats the reason I made this post. Mine was essentially acting like a wastegate and I have carbon and soot back down the rubber/metal hose all the way to the secondary air pump...
