Boost Gauge Question
I just installed a air pump delete kit and removed a few hoses. I also just bought a boost gauge and wanted to know if I can use this vacuum outlet to the boost gauge. I know that most people use a tee fitting to the fuel pressure regulator. But for a cleaner look I was wondering if I can just use area where one of the air pump hoses use to be.
http://i90.photobucket.com/albums/k2...lu3/vaccum.jpg |
If you get a block off plate, you can remove that thing to the upper right of your arrow.
I think that is fine, though. Sent using free Tapatalk - Android FTW |
Yeah i got the block off plate from puddy.
Yes, you can use that.
| All times are GMT -8. The time now is 04:51 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
