bov problem
i just installed a godzilla bov on a comptech a\c sc kit w\ stock pully and i get no sound at all out of it. if you rev the engine up and put your hand in front of the bov you can feel air comming out of it but it does not make any noise. has anyone had this problem or know what might cause this?
Check your vaccum line for leaks, you might also need a more direct source of vaccum instead of using the "T" on the existing lines. Using a larger vaccum line seemed to have positive affects with my stock bybass valve also. If the godzilla has a spring tension adjustment, you'll want to loosen that up. Also, check if the valve is binding (manually pushing on it), and try lubricating it up.
My $0.02,
Matt
My $0.02,
Matt
Do you have a boost gauge in the car? I'm just asking because your car won't boost if you are revving it in neutral. Did you drive the car yet? You can also try tightening/loosening the spring on that BOV.
Originally Posted by Dsgs2k3,Aug 30 2006, 09:20 AM
make sure you have all the vaccum lines in the correct place. maybe switched up the lines
As above. More like than likely, you've plugged the wrong vaccum hole. And only plug the top one, not both. Leave the other one empty.
Use the top one on the rear (Or in front/the most top above one - If you have the BOV mounted upside down with the vent pointing downwards instead of upwards.) You will hear it vent/whine loudly @ approximately 3500 RPM in precision with the spool -> louder as the RPM increases.
And yes, it does spool even with no load. Those who say it does not, you need to check whether if you have a blower under your bonnet.
thanx guys for the help. i checked the vac lines and it turned out that the chk valve on the one vac line was actually cracked which was leaking and loseing pressue. i changed the chk valve and it fixed the problem. it was also causeing a chk engine light issue which the shop i had the comptch sc installed at could not find the problem. now both are fixed thanx for all the help.
Vaccum lines wrong
