Can an oil cooler effect oil pressure? Low(er) oil pressure issue
So I don't think there was an issue
An easy way to deal with this and reduce the size of the oil lines you have to run is to drill a hole in the sandwich plate going from oneside of the plate to the other.
I used a 9mm drill bit and then used AN8 oil lines and i suffer no oil pressure issues at all. There is no need to try and force all of the engines oil through a restrictive cooler. By drilling a hole you are giving the oil an alternative path to go through so when your at low RPMS it will use the drill hole and when that hole becomes restrictive oil will start flowing through the oil cooler. Even if you only had 10 liters per minute going through the oil cooler it would still provide plenty of cooling effect. Plus you are less likely to burst the cooler which can happen when it starts becoming restrictive.
The S2000 oil pump moves 60 litres per minute at 6000rpm and you will struggle to find a cooler that can handle that flow rate without causing a restriction. The only way to reduce restriction is a better core or more rows. More rows isnt a great idea as fitment becomes an issue. I opted for a full length 19 row cooler.
My oil cooler was alot easier to install with narrow AN8 lines and im having no issues with oil temperatures on my supercharger set up.
with any heat exchanger you should calculate the internal flow area to make sure there is not a significant restriction to flow. any time you lengthen the distance the oil has to travel there will be a drop in pressure due to surface area drag coefficient. so the longer the flow path of the core and lines included, the more pressure loss you will see. the same applies to intercoolers and radiators.
The S2000 oil pump moves 60 litres per minute at 6000rpm and you will struggle to find a cooler that can handle that flow rate without causing a restriction. The only way to reduce restriction is a better core or more rows. More rows isnt a great idea as fitment becomes an issue. I opted for a full length 19 row cooler..
Yeah thats exactly what i done. I use the mocal thermostatic sandwich plate as well and i still get good flow through the cooler and its always hot to touch after a long run. The only thing i dont know is whether the oil rushing passed the drilled hole would gradually erode the aluminium. Probably just paranoid but thats my only worry.
I was just worried about the oil flowing past the sharp edge of the drilled hole causing it to wear away but now you mention it the chances of it doing any damage are very small. Well assuming the ali mocal use isn't stupidly cheap
I am running the mishimoto plate. Do you have any pics of the hole you drilled? I shimmed the oil pump a bit and it helps but long periods in VTEC with high oil temps lead to pressure drop. I see 60-65 psi at 235f but normal driving I get 75-80psi cruising around even with hot oil temps around 220_230f. My pressure per the manual is good as I have 75-110 psi cold start summer winter. And full hot idle is 12-20 psi.
