Car dies ?
Old Jan 19, 2012 | 05:52 AM
jpetch05's Avatar
Default Car dies ?
After I had went FI. I had relocated my battery to the trunk, and at that went with a crazy ass odyssey battery. Not a skinny small one, I'm not at home to check it but it's a legit battery.
Now, half of the time when I put my top down, turn not in gear just coasting, or turn on my headlights, my car will stall.
1. Do I need a beefed up alternator ? Is mine bad ? It has about 26k on it and the car is an 02
2. Is it a tuning issue ?
Input ?
jpetch05's Avatar
I plan on running AC this year so I need to fix this issue
Old Jan 19, 2012 | 06:15 AM
Rollinx25's Avatar
Check your battery connections... If they are loose at all it will cause your car to die.
Old Jan 19, 2012 | 07:41 AM
jpetch05's Avatar
They aren't loose for sure
Old Jan 19, 2012 | 09:33 AM
DFWs2k's Avatar
what EMS
Old Jan 19, 2012 | 11:44 AM
jpetch05's Avatar
Aem v2
Old Jan 19, 2012 | 10:41 PM
s2k manic's Avatar
pull bat cable while idling if car dies look to alternator at least it should rule it out.also make sure you have high strand cable and a good ground
Old Jan 19, 2012 | 10:44 PM
9krevvin's Avatar
What Gauge wire did you use for the relocation. If you used to small of wire it may not be able to properly carry current. You need to use a minimum of 4 gauge wire. I am also using a 100 amp circuit breaker with my setup.
Old Jan 20, 2012 | 05:09 AM
jpetch05's Avatar
So none of you had this problem with your cars after turbo ?
Old Jan 20, 2012 | 05:36 AM
DFWs2k's Avatar
Nope, my car has been perfectly fine except for an axle breaking after doing a clutch dump.
And gas mileage is better than NA.
