Go Back  S2KI Honda S2000 Forums > Special Interest > S2000 Forced Induction
Reload this Page >
Car running lean after startup
Old 06-19-2019, 01:40 PM
Default Car running lean after startup
Need your help, car start running lean today.
I have a novi1000 1000injectors.
Here's a video
https://youtu.be/JeuuxhoDu9o
What should I check for??
S2kdavis is offline
Old 06-19-2019, 04:22 PM
Here's a video
First thing I would do is check to make sure it’s not a sensor problem... that seems crazy jumpy. I have the same gauge and it does not bounce all over the place like that
outeiroj is offline
Old 06-19-2019, 04:28 PM
Ok, I'm replacing it tomorrow
S2kdavis is offline
Old 06-20-2019, 08:26 AM
AP1Chief's Avatar
what tuning software?
AP1Chief is offline
Old 06-20-2019, 08:38 AM
Aem v2. Do you think it can be the wideband sensor?
S2kdavis is offline
Old 06-20-2019, 09:46 AM
theres actually a way to check if its reading properly. forgot to mention on my first post. but if remove the wideband sensor from the exhaust, turn the key to the on position, take a rag and spray brake cleaner on it... and cover the tip of the sensor with the rag it should make your gauge peg rich. When I first got my aem uego i was running into an issue right out of the box, and that test helped me verify a bad sensor and once i replaced it, everything worked fine
outeiroj is offline
Old 06-20-2019, 09:58 AM
just make sure you buy a bosch LSU sensor and not some ebay crap. AEM are bosch sensors, just rebranded and marked up 300%
Charper732 is online now
Old 06-20-2019, 01:03 PM
I did the test and it still show full lean. I'm going to replace with Bosch 17014. Is that right?
S2kdavis is offline
Old 06-20-2019, 03:26 PM
depends if you have the 4.2 or 4.9... amazon sells the 4.9 sensor for 88 bucks
Amazon Amazon
outeiroj is offline
Old 06-20-2019, 03:30 PM
Depends. AEM uses one for their gauge kit and the other is used with their EMS...it's fking stupid as hell
Quick Reply: Car running lean after startup
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
