Car wont start
hey i thought id come here for help since ive tried everything. I just relocated my battery into my trunk im running a 4 gauge wire from the front to the back i have a circuit breaker hooked up in the front and connected to that is the 4 gauge wire going to the trunk and the two wires that were originally connected to the battery one is going to the fuse box and the other idk where it is going. And then in the trunk i have another circuit breaker hooked up from the 4 gauge coming from the engine bay and off that is the positive to the battery. im running my ground from the engine bay to the trunk also and it is grounded up in the original spot then grounded to the bar in the trunk by where the spare tire should be and also grounded right there is the battery. thats my setup and im getting power but once i try and start the car will start cranking but wont turn over. Im pretty sure thats everything any questions let me know but hope you guys can help me figure this out
First off, by reading it you have a few unnecessary things in your relocation, and a couple things I would personally change, but if the car cranks but does t start you either have no spark, no fuel, or your crank positioning sensor is bad, one sma thin I would try is unhook your battery, then unplug your crank positioning sensor, rebook your battery after about a minute, if your cps back in then try starting the car
This may sound silly but are you sure you didn't pop a fuse while moving all those wires. Easy thing to do and overlook. Go back over every connection you made as well and make sure everything is tight and no possible short to ground scenerios. Then start looking around where you worked in the engine bay. Maybe accidentally left something unplugged or loose. Finally check all your fuses under the hood and inside the car. You'll find what the problem is if you simply eliminate the variables one at a time. If it cranked before it will crank now, your just overlooking something. Good luck.
