Cc Twin disc question
I have a few questions. Do we need to install a pedal stop or do you just do adjustments to the clutch pedal? And the lines that come off the throw out bearing does one hook up to the master cylinder and the other is the bleed?? Pictures of the setup would be nice , just trying to get a idea before I install this.
Yes, the instructions from Competition states to install a manual clutch stop to prevent excessive throw out bearing action and consequent thrust bearing wear. Forgot to take pictures of my lines during the install, but 1 is for the master cylinder and the other is for the bleeder, as you said. If after the install and initial bleed and you don't have any clutch pressure, disconnect the bleeder fitting and pump some pressurized air through the system (brake fluid will back out the reservoir), reinstall the bleeder fitting, refill, and bleed again.
The switch should have some adjustment to it as well. You should be able to get it to work; if not you can make up a new mount for the switch or for the nylon piece that depresses the switch.
Don't depress the clutch on starts, especially cold starts, and don't sit on the pedal at lights.
I don't have a stop, but my clutch is engaged out enough that I'm not overextending. Still plan to weld a stop up within the next week or so just for peace of mind.
