Clutch and gears?
Old 02-20-2005, 04:16 PM
nsxinsac's Avatar
Post Clutch and gears?
Which clutch and flywheel would be recommended for a S/C application? I would like to get one that will handle the extra power with being as streetable as possible. Would like to avoid harsh engagment, and bad shuddering. Also, are building the rear end and getting gears recommened with a S/C application?
Thanks
Old 02-20-2005, 05:16 PM
Slows2k's Avatar
The ACT street clutch has had pretty good reviews from all the SC'd owners. Since it uses a OEM disc, it's as quiet as the original.
As far as gears go, That's more of a personal preference. everything from the stock 4.10's to 4.77's have been used.
Check this out for speed in each gear:
Reverend's gear calculator
Old 02-20-2005, 09:16 PM
Wisconsin S2k's Avatar
I'm going to move this to FI.
From what I understand, the stock clutch is fine, it's the pressure plate you'll want to get. something along the lines of ACT's HD Pressure Plate. Also change the throwout bearing (you can use the OEM bearing) since they will have it apart anyways.
There are a few other ideas about flywheel. Some get the OEM one lightened while others get an aftermarket flywheel.
as for the rear end, it depends on how you drive it. If you go aftermarket, IMO, I'd go with the 4.57 gears, since they are made for the S2k and are stronger than the 4.77's. I'd also get the comptech reinforced diff if you plan on driving like me. lol
Old 02-20-2005, 09:34 PM
C45P312's Avatar
ACT Heavy Duty Pressure Plate
Comptech flywheel
OEM Disc
OEM Throwout bearing
ValleyN/AS2K
09-07-2013 12:24 PM
dsddcd
06-03-2012 09:26 AM
BerlinaBlack_AP1
08-30-2010 01:08 PM
BaronRojo
04-07-2005 06:33 AM
pinoydarv
01-15-2005 07:21 PM
Quick Reply: Clutch and gears?
