CNC 2.4L kit w/SOS s/c (novi1500) vs f22c w/ hks s/c kit
Yeah just read up on compression and knock and how they work together. I do still want to try a 3" cat back to see what happens. Very interesting though. Makes me feel like I should've just bought an Ap2 motor lol.
150 IAT is very high. Definitely narrowing the window of detonation. 152F is the peak I saw when my aftercooler pump relay failed and was getting no fluid movement through the pump, I also heard the engine ping getting around town before I noticed what had happened. I would question if your aftercooler is even working? With a properly working large heat exchanger you should be about 125F max and 115F average.
Originally Posted by killerbee_vr6' timestamp='1448382025' post='23811494
The lost power is in the dropped compression. You probably lost 10% of your potential power there.
Your IAT is a bit alarming to me, coupled with 1-2 other smaller things all of which combined may explain your current numbers. Thats my educated guess with the info you have provided so far. If there are deficiencies in how your set up is operating, the tune in order to be safe, will be extremely conservative to keep the motor from detonating. So a good tuner will do this based on how he is seeing the engine operating on the dyno. An even better tuner will be able to pinpoint the out of ordinary issues and fill you in on what to address. That accurate assessment is a bit more rare unfortunately I have found, which is why you are here, to figure out.
Originally Posted by cheddaboy' timestamp='1448390129' post='23811647
[quote name='killerbee_vr6' timestamp='1448382025' post='23811494']
[/quote]
Iat is definitely the pump that isn't connected or working properly(gotta play around with that).
The tuner also said that the fuel system is maxed out and suggested a bigger fuel pump. Now that you mentioned it could be on the conservative side, I think it is. What fuel pump should I be looking for(e85 compatible)?
What water pump do you have for the aftercoler?
You need this beast of a pump which I just bought.
www.siliconeintakes.com
1 x Water to Air Intercooler Pump and Harness, Bosch Cobra (WAT001001) = $124.48
Mounting Hardware Included
The bigger issue here is the high IAT and likely the sub par/conservative tune revolving around that high IAT to get the engine to operate without destroying itself.
