S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   Converting to fuel return (https://www.s2ki.com/forums/s2000-forced-induction-142/converting-fuel-return-1148321/)
Rays S2k Mar 14, 2016 10:01 AM
Planning on boosting my06 within the next month I already ordered a fuel return kit now my question is can i install it and be fine or will I need to do something with the stock tune
King Tut Mar 14, 2016 10:28 AM
Stock tune should be fine as long as you run the same fuel pressure on the regulator.
Rays S2k Mar 14, 2016 10:31 AM
OK awesome do you happen to know what the stock fuel pressure is
King Tut Mar 14, 2016 10:34 AM
I wanna say it is 63.5 psi according to Hondata, but I will have to check my tune file when I get home to verify.
Rays S2k Mar 14, 2016 10:37 AM
Originally Posted by King Tut (Post 23908152)
Originally Posted by Rays S2k' timestamp='1457980297' post='23908147
[quote name='King Tut' timestamp='1457980110' post='23908142']
[/quote]
OK awesome please let me know thanks.
TUKES2k Mar 14, 2016 06:36 PM
pretty sure its 43.5... are you changing the pump and injectors?
Rays S2k Mar 15, 2016 04:11 AM
[/quote]
Yes I'm doing fuel pump once I install the turbo then I'll install the injectors
TUKES2k Mar 15, 2016 05:17 AM
Gotcha... so you pretty much just wanna install the fuel lines and regulator
liquidgsr Mar 15, 2016 05:20 AM
What kit did you go with?
Rays S2k Mar 15, 2016 05:21 AM
I went with pfab stage 2
© 2026 MH Sub I, LLC dba Internet Brands
