couple questions
Old Sep 20, 2009 | 04:05 PM
josh7owens's Avatar
Default couple questions
whats the difference in a $200 no name intercooler and a full-race $700 intercooler? also if I'm gonna stay around 12-15 psi (stock internals) what size wastegate and bov should I run. I'm shooting for 425whp but I would like to have the option to up the boost/power after I built the rear end. Wheres the cheapest place to by a gt35r?
Old Sep 20, 2009 | 04:26 PM
chad86's Avatar
The intercooler will not flow as well and won't be as sufficient in cooling the air.. at 15 psi yopu would need to be runnin a higher octane fuel or meth injection etc... In all honesty if that6 is the power goal you weant oyu should just get Mases new kit and be done with it.. His is 400 whp out of box and can be upgraded to fit larger turbos... depends if you want to build your own or not tho i guess... good luck
Old Sep 20, 2009 | 04:29 PM
josh7owens's Avatar
mases kit is 6500 plus the little stuff you need. DIY will be like 3k lol
Old Sep 20, 2009 | 05:03 PM
chad86's Avatar
FI for this car is expensive... especially if u want good numbers.. A good ems will run about 1000 alone... turbo 700-1000.. Boost gauges, oil pressure,AFR.. It all adds up.. I am not saying a custom kit can not be done, but IMO just do it the safe and easy way.. Save up >>If your budget is only 3000 I would honestly reconsider and think about saving a little more cash...
Old Sep 20, 2009 | 08:23 PM
josh7owens's Avatar
well what i plan on doing is piecing a full race or similer kit togeather. used mani, db, intercooler (maybe), ect. that way I'd save money. its not like a mani is gonna go bad or somthing.
Old Sep 20, 2009 | 08:32 PM
Ian300D's Avatar
$3k can do it, but not very safe. Who knows though I got a full kit for $3k, but that wasn't including ecu or tune. Ya it adds up very fast.
Old Sep 20, 2009 | 08:47 PM
josh7owens's Avatar
used i take it. I agree it does add up quick but its easier paying for it a piece at a time lol
Old Sep 21, 2009 | 10:02 AM
fanaticz's Avatar
It seems like I remember reading the more money you put into a car upfront the less you'll pay for later. Especially with an already expensive car.
Old Sep 21, 2009 | 10:10 AM
Spec_Ops2087's Avatar
You don't have enough money for that power level most likely. Save up or prepare to have headaches. Simple as that
Old Sep 21, 2009 | 10:18 AM
jdnissanz's Avatar
You can definitely piece something together for $3000, and I wouldn't even question the quality. But keep in mind that you should have about $1000-2000 ready for small issues that add up, or a large issue due to the turbo kit! There is no such thing as a plug and play turbo kit no matter what anyone says, especially at those power levels!
Monacos2k
May 29, 2015 12:17 PM
robertm
May 24, 2014 11:09 AM
admans2k
Sep 28, 2013 07:51 AM
SpoolinU
Sep 24, 2009 06:49 PM
SuzukaS2K
Mar 4, 2003 06:58 AM
