Crankcase blowby thru oil filler on superchrged AP1
Hi,
I have a 03 AP1 with a SOS supercharger and I noticed that at idle I have a significant amount of air coming out of the oil filler with the cap off. I pulled off the vent line and the pcv valve, and a strong stream of air comes out of all of the holes at idle. I also smell oil after a full throttle run. Is this normal? Possible broken rings/scored cylinder?
Thanks!
Thanks!
Yes it is normal to have air coming through the ports in the valve cover. The difference is how much air and if it's enough to show a sign of trouble with the bottom end. Chances are you're fine, but do a compression test and/or leakdown if you're unsure.
Sent from my iPhone 4 using Tapatalk
