CT engineering kit Novi 1200
I purchased a CT Engineering kit and I love everything about it but I am trying to get into the 360-380 whp range. I am running a Novi Paxton 1200 blower . I am currently making 301 whp and 209 ft lbs torque. I spoke to CT and they said they do not stock any crank pulies or supercharger pullies. I also called science of speed and they said for the ct novi 1200 there is no pullies that thewy sell. So I have a competetion in may and getting that extra hp would be great , any advice guys. I have been doing my research as best as possible but I cant seem to figure out how to squeeze more power safely. I mean I can always run e85 and start making power through timing but that is risky.
Yeah that’s pretty weak to hear. I had no idea this was an issue with the new gen blowers on the new gen comptech kits. This was never a problem with the old comptech kit. SOS would seem to be a no brainer, except for the Carb legal aspect I suppose. For the CT guys, i'm sure you can have a custom pulley made through one of your local machine shops, or may have to send out if you have no good ones around. There is a ton of different pulleys out there for different blowers. If non is made specific for the CT kit, you may get lucky and find one you can retrofit by adding offset spacers, or even honing out the shaft size if you find the right offset but too small a shaft diameter. There is always a way, just have to research. I took a rather generic alum pulley I found off ebay and honed the shaft bore to fit a novi 1000 and then added several washers to the face and back to dial in the offset. I did this becuase I wanted to run a pulley size that wasnt made for the blower. It worked great.
I've tried to see what combo I can mix and match but it seems that a SOS pulley just won't work on a ct novi 1200 blower. I am going To see if ct can just make
Me a custom pulley. I can't even get a larger cranky pulley because they are out if stock.
It seems like or you have personally verified it does not work? I can send you a SOS pulley to see if it fits your Comptech kit if you like.
