Cylinder Head Parts Rebuild for Turbo
Hey Guys,
I have an Ap1 and will be soon rebuilding the head. I will be boosting the S probably sometime in the thanksgiving and Christmas season. My target is 300whp. Will the stock springs work for a boosted car? I'm trying to stay on a budget.
Anyway, the parts I'm planning to get are:
If you guys have any recommendations or experience with these parts. Feel free to comment.
- Ferrea 6000 series STD size Valve Kit (F6329/F6330)
- Supertech Bronze Valve Guides (GDE-HS255-I/GDE-HS255-E)
- Brian Crower Valvesprings Steel Retainers or Supertech 92lb Dual Valvesprings Retainer or Stock Springs
- Ferrea Valve Locks
I have bc dual springs, steel retainers, and bc keepers. I had no problems with them still in my car now never even pulled the head to install them, I wouldn't trust oem springs. I'm about to pull the head and build it soon. I'm going with the Kings performance kit so I will be selling the bc's if your interested PM me.
I agree, stock head is more then adequate for your goals. The only thing that would be reasonable to do wile its apart is to update it with the ap2 valve keeper and retainers. These are a weaker point on the f20 heads in those mechanical over rev situations. Will help keep you from dropping a valve. Stiffer dual springs just added additional load and wear to your parts so its a trade off for valve control, but if your not pushing the power requirements to that threshold of needed added valve control, then your just spending money for a compromised set up. Titanium retainers have also been known to have questionable longevity and reliability in some cases seen on this forum. I would consider aftermarket valve train at the 600whp+ mark. That's your threshold.
So do you think it'd be better to use:
Ferrea Valves
Ferrea Seals
Supertech Bronze Guides
Stock Springs, Retainers (Ap2), and Keepers
Or should I go with aftermarket retainers and keepers?
Would it also make sense if I went dual springs just in case I over-rev again?
I'm on a budget so I'm trying to keep the cost to minimum if I don't have to upgrade the springs that would be cool.
Ferrea Valves
Ferrea Seals
I made over 600whp with stock f20 head with ap2 intake retainers and keeps with no issue what so ever for quite a while. I have since upgraded to full supertech valve train and it was honestly a waste of money. It made no difference.
You'll be fine with Supertech valves and stock springs and Ap2 retainers and locks. Save the money. However, if you plan for more power later, it would save you the money and time if you do it now. We have all instock.
wadzii
09-03-2013 04:39 AM
