Dry Sump with Supercharger - Any Ideas?
Hi All,
I'm running an SOS supercharger kit and would like to go dry sump for track duty. The problem I'm encountering is the blower belt pulley takes the space needed for the oil pump drive gear. Has anybody seen a solution for this problem? I reached out to SOS and they didn't have a solution. Thanks in advance. Dave |
You will likely need to design and produce your own system for this.
This "car" is dry sumped with supercharger, maybe worth a look :)
https://www.s2ki.com/forums/car-talk...ipient-971735/ |
If you have dry sump money, im sure fitting a different power adder would be no issue in the budget...
The problem we have with the S is clearing the steering rack since it sits right in front of the crank pully, or id say just stack another pulley there. When you add the supercharger drive pulley you have about 1/2" clearance at best. So it would seem that option is out and figuring out a new bracket and mount point somewhere else to run off the acc belt would need to happen. I have not seen anything like this off the shelf for our car. Too limited a market.
Run electric pumps like BMW does?
