EFR 7064 Twin Scroll / IWG / Pfab Top Mount / V-Mount build
#121
I did street tuning/logging on this to what I already knew was safe timing. I always wanted to get it on the dyno to see where it best liked timing, but never put any priority on it. It ran great and I tracked it for 3 years with this tune, so I was happy. For the turbo, I'll do some street tuning, then put it on a dyno.
Never used that ECU conversion, however, if it works and does what you need it to do without failure or oddities, I'd imagine it works just fine. I also like to look for options that don't require a ton of work just to get it hooked up and able to tune.
The blue SHO I posted was done with a stock ECU with a programmable chip hanging off the J3 port. I made it work, but showed its limitations... The car is currently getting a wiring harness built for an AEM Infinity so we can have far more control this year.
#122
#123
Yeah, I tune a lot of OEM ECU's, with the AccessPort / AccessTuner, which is what the left map was on that picture (flex fuel tune for a guy in Omaha).
The only reason I went with and AEM on the S2000 is because I couldn't tune the stock one. If that option were available years ago, I might have gone with that.
#124
Yeah, I tune a lot of OEM ECU's, with the AccessPort / AccessTuner, which is what the left map was on that picture (flex fuel tune). The only reason I went with and AEM on the S2000 is because I couldn't tune the stock one. If that option were available years ago, I might have gone with that.
#127
Maybe not this version, but there was another option that required swapping sensors that I wasn't up for doing. In the end, the AEM is far more capable, which will work out for me now with boost.
#128
yeah thats true, only thing is for those of us that might have to smog its easier to have an ecu that maintains OBD capability
#129
Now that I am home, I got to open up the new replacement parts... The saga continues. The new one has a bent bracket and the box looks fine. There are also marks on the bracket likely indicating it was done before being put into the box. What a huge disappointment and regret to go with Science of Speed. I was hoping to fire this thing up soon.
#130
