S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   Electronic Boost Controller Question... (https://www.s2ki.com/forums/s2000-forced-induction-142/electronic-boost-controller-question-423505/)
XclusiveAutosports Sep 19, 2006 06:02 PM
Hey guys, I just picked up a Profec E-01 and I want to install the boost controller tomorrow, but I know that I won't be able to dial it in until I bring it back to the dyno for another tune. So my question is if I would be able to hook up the boost controller with re-routing the vac lines from the turbo and the wastegate, and hook them up to the new solenoid/controller, and if I turn off the controller will the car still run off the wastegate spring? Any insight would be appreciated. Thanks. :thumbup:
AROD Sep 19, 2006 06:16 PM
yes it will still work off the wastegate spring :thumbup:
XclusiveAutosports Sep 19, 2006 06:18 PM
Good to know, thanks again for hooking me up. :thumbup: I'll slap this bitch on tomorrow. :)
Venomous S Sep 19, 2006 06:40 PM
hmmm, u shold've asked me first
I am sure it's a good unit for controlling boost but i could not get the damn thing to work. Even after calling profec, which by the way they do not even have a clue how to even do it. Either that or I spoke to some schmuks.
I would honestly recommend a manual unit. when I tried what they said my boost curve was all over the place, did not even make sense at all.
But good luck regardless.
PS. I am only using it to datalog as I connected my wideband to it.
Kwando Sep 19, 2006 06:43 PM
i see you are using EMS why not just get a GM boost solenoid? just curious.
XclusiveAutosports Sep 19, 2006 06:49 PM
I actually have a GM boost control solenoid, but I figured that it would be too much of a PITA to get set up so I thought I would go with an electronic boost controller instead. Looks like this is going to be a different headache now, damn.
XclusiveAutosports Sep 19, 2006 08:22 PM
Hey, O'neil... can you check for me how you set up your vac lines so I can double check how I am thinking it should go. I know that the pressure sensor needs to be tapped from the FPR vac line (I already have my BOV and Boost Gauge tapped off here, is it ok to tap it a 3rd time?). Then I am thinking that the "COM" port on the solenoid valve should go to the top of the wastegate, and the "NC" side should go to the compressor tap on the turbo. Is this correct? Thanks. :thumbup:
Venomous S Sep 19, 2006 09:42 PM
[QUOTE=XclusiveAutosports,Sep 20 2006, 12:22 AM] Hey, O'neil... can you check for me how you set up your vac lines so I can double check how I am thinking it should go.
XclusiveAutosports Sep 20, 2006 09:23 AM
^ Thanks bro. :thumbup: I'm going to install it now. If the controller doesn't work out then i'll just uninstall it and go with a manual setup. I was just looking for something that can allow me to change between low/high boost on the fly so I can use the tune I have now for daily driving and then have a tune for 8 or 9psi for the hell of it.
Venomous S Sep 20, 2006 03:36 PM
Well, with a simple manual boost controller, you can turn the know on the fly also
© 2026 MH Sub I, LLC dba Internet Brands
