Out last night driving in this awesome weather we're starting to have again. I hit boost cut which is set at 15psi. I think this was rolling hard from the bottom of third.
Not an error, those are real values. Is my car possessed? Lol
hey spectacle, thanks for all the tunerview info, do you mind saying what you have on the diff pages? It seems like you can get all the important stuff on one page...
I wish he would have a medium for rpm/whatever else, so you could do that and maybe 4 other parameters
Not sure what you mean by that.
I can't tell you exactly what I have on each page because I don't remember. As a matter of fact, I need to go back in and reprogram a page or two. But for the most part, I have everything setup with correlation in mind. My startup page is a big gauge for ECT. My main page I use 90% of the time has the AF, ECT, IAT, and MAP on it. AF, ECT & IAT have their numeric values on the left and are 'graphed' on the right side. So at a glance during a pull, I can visually see my AF's go richer with throttle similar to a boost gauge as well as keep an eye on the other vitals. It is very easy to see exactly what's going on the way I have it setup...so for this example you know during a pull IAT and AF's should be going down while ECT's might climb slightly. I can verify this with very quick glances and still keep my eyes on the road. The only thing I don't like is the graphing bar for AF goes the opposite way than I think it should - as AF's get richer the graph empties instead of fills. I'd like to see it go the other way. Maybe I'll bug JR about it when I decide to reprogram it here shortly.
The tunerview is an awesome tool...I'll make a video for you guys if you like.
what i mean by medium is, if you have a large parameter, then that's the only thing that shows up, or you can have small parameters, and then you can fit 8 of them on the screen, i wish there was a medium that took up the top half, and then you could put 4 smaller ones below that
