exhaust gasket for turbo
I used "The Right Stuff" by Permatex on mine and don't have any leaks at all.
Originally Posted by Chitah831' date='Feb 9 2005, 06:08 PM
^^ Same here.
BTW, Spoolin are you running UR's exhaust?
I just got my 3" downpipe, high flow cat, and 3" dual exhaust from UR put on. Has your boost crept up any higher? Mine is boosting 9psi now where as before it was about 7 or 7.5.
BTW, if you're running the older stock tips you should switch to the 04 tips. They look AWESOME!
Well at least you have some cool tips too
I am going to have it dyno tuned soon on my AEM EMS so I'll get back to you on the numbers. My tuner does estimate my car is close to 350whp and he has tuned LOTS of cars. But can never tell till dyno day.
I don't have a oil pressure gauge so I can't comment on that one. Hopefully someone else will help you out with your situation.
I haven't pulled anymore timing since the first tune. I'm running about 16 degrees in boost. How about you?
I'm debating on whether or not to go with a smaller wastegate spring.... just to be on the safe side. Car sure feel strong though!
Just an estimated 350whp... dont know for sure yet
Everything is still stock, timing and all. My tuner, which was Payne Technologies out of Troy MI if you recognize the name, just left everything stock. But said that I may want to pull some timing at the top end eventually. Sometimes, with 93 octane gas, I can here a little weird sound coming from the engine. Not sure if it is detonation or not but Payne told me he didn't here anything that sounded like detonation to him. Hopefully it isn't.
