Extended slave Clutch push rod - advice
I have a question and in need of advice.
I installed a stage 3 pressure plate and paddle clutch disc. I also bought a new flywheel from xtreme. I keep bleeding the clutch and I'm not getting a good throw in the rod to the fork. There is no air in the system. The pushrod throw to the clutch fork has very little movement (say 1/8). I checked the slave clutch cylinder and measured the pushrod, I found out the rod length is max out and can't push any longer. First, why is this happening? I read somewhere that when using a hi-performance clutch, you need an extended rod get a little bit more throw to release the clutch. http://speed-source.net/?wpsc-produc...clutch-pushrod I have no choice except to buy 1/4 more extended pushrod. kindly advice.... |
Adjust the screw on the pedal its self
| All times are GMT -8. The time now is 10:19 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
