F1 EFR 7670 Twinscroll External Wastegate Full-Race kit install
https://cimg6.ibsrv.net/gimg/www.s2k...dc970910ad.jpg
I made another thread addressing how many turbo'd s2k's end up for sale. I didn't want to end up being that guywith a 'pretentious build'. I want to keep it simple and enjoy my s2k until death do us part. I wanted to take on a build and be able to replace and diagnose parts myself in order to avoid the stealerships or jiffy lube mechanics at all costs. Being so committed and knowing what I want makes it easy to set up my parameters for this build: For this build i wanted to use quality parts, delete unnecesary components to free up space and complexity to wrench around the car. I want to put things together in a way that will maximize engine efficiency/longevity/refinement/keep things easy to diagnose/pull apart and replace. My turbo build parameters: (1)Make max amount of power out of an AP2 shortblock for street use/highway pulls. (2)Have a setup that will minimize turbo lag. (3)Keep stock look/sound including oem wheels, mufflers, motor mounts. (4)Rev to 10K rpm's (For the sound, uniqueness, and traction philosophy of laying down power up in the rpm's let's you run smaller tires and keep traction ala highhorsepower fwd civics style). Devil is in the details, basically am shooting for 650whp with earliest spool/best transient response possible in an oem’ish looking AP2 that can rev to 10K RPM. Parts(reasons) are below, again this is to guide and inform anyone that might want to learn in the future of a very detailed goal oriented build. Turbo BorgWarger 7670EFR turbo which features:
Full-Race Twinscroll Dual External Wastegate Turbo Manifold:
that will help engine spool turbo up faster directly or indirectly/handle more boost:
https://cimg1.ibsrv.net/gimg/www.s2k...3b2ba59f47.jpg
My old greddy kit i removed a few days ago |
https://cimg4.ibsrv.net/gimg/www.s2k...11c3f076cd.jpg
Thinking of removing this vtec pressure switch to feed oil to turbo https://cimg8.ibsrv.net/gimg/www.s2k...fb0eab5b57.jpg |
https://cimg4.ibsrv.net/gimg/www.s2k...ec1b47dee6.jpg
Plan to install this 6\" velocity stack and air filter. Isnt as much space as i thought to make it fit. Turbo has 3.5" intake. This was on my wishlist for my build so ill have to make it fit somehow. Good news is that its right where an intake needs to be on turbod s2k. Near passenger headlight away from exhaust |
Its gonna spool what it spools at.... not much you can do LOL
BW EFR turbos should have the best spool. TTBOMK are the only turbos with titanium aluminide turbine blades. Garrett went with hi-temp MAR-M on the new G-series, but that isn't lightweight.
For some reason Full-Race doesn't list their kit with an internal wastegate divided T4, but I imagine they would build it. The 1.05 AR EWG T4 they list with their manifolds should scroll as fast as the .92 AR twin scroll on a IWG T4 manifold, although the spooling difference should be small. Give them a call. Note that they build an EFR IWG manifold for the Supra with a 2JZ-GTE, so it wasn't an IWG issue. I don't think there is any reason to not use the IWG on the EFR and its built in recirculating BOV. It also comes with a 3-port boost controller mounted on the compressor housing. Common changes are to use the Turbosmart IWG wastegate controller, a direct fit, and either Turbosmart recirculating Kompact BOV (they have a model that screws as a direct replacement) or the Full-Race aluminum cover over the EFR BOV. There is a guy running a compound turbo S2000 with two EFRs. Videos on YouTube and I believe a thread here. Sound Performance has a Quick Spool Valve (not cheap) that fits between a twin scroll T4 turbine housing and a non-divided T4 manifold. It has a flapper that directs the flow to one scroll. 4 years ago BW displayed an EFR turbine housing that had a similar flapper built into the housing so it could use a divided T4 manifold, but it apparently never made production. Then, of course, there is anti-lag. BW has a speed sensor for the EFR and an EGT sensor may also be helpful to avoid excessive turbine spool or temps. |
Boost, fuel, and horsepower levels aren't specified. If the power level is under 500-550 and/or a oxygenated fuel is used, it may be possible to use the small frame EFR, such as the 7361, rather than a big frame EFR. The smaller turbo should spool faster.
https://cimg4.ibsrv.net/gimg/www.s2k...e50e99d257.jpg
Not much done today but i was able to atleast get the filter more in line. |
https://cimg7.ibsrv.net/gimg/www.s2k...5ce9f754d0.jpg
Plenty of space to install and get to the factory oil filter. Not going to miss using an oil filter relocation kit! Oil relocation kit just adds more complexity and possible leaks/take up vital space/are in a really hot environment. Plus not having to pump through an extra 2ft of hoses should make oil pump and oil pressures happier |
