fuel consumption way up
Old Oct 6, 2006 | 09:42 PM
news2kroller's Avatar
Default fuel consumption way up
When the s/c first went on stock ems and injectors i didnt notice my MPG go down at all but after my injectors and aem ems i have gone from about 22mpg to about 12 Is there something wrong here?
Old Oct 6, 2006 | 09:58 PM
Sideways's Avatar
It's all in your right foot.
Old Oct 7, 2006 | 04:43 AM
Reborn56's Avatar
Lmao.
After installing the ingectors and aem did you get it tuned?
If so he might have tuned it very conservative.
Your prob running pretty rich.
Marcus
Old Oct 7, 2006 | 06:55 AM
geists2k's Avatar
You need to see a tuner.
When my EMS was installed and simple base map was set up, I think I was getting about 13mpg on the way to the dyno.
My car was getting worse milage than my 2005 Expedition!
Old Oct 7, 2006 | 07:10 AM
John_Z's Avatar
If you have a wideband check your A/F. I'm seeing low 14's when cruising at freeway speeds.
Old Oct 7, 2006 | 07:35 AM
inlinepro1's Avatar
Yikes.
Old Oct 7, 2006 | 07:41 AM
kane.s2k's Avatar
no need to be conservative when under low loads/cruising. I'd get things checked out and be sure it's in the mid-upper 14's with extremely low loads.
Old Oct 7, 2006 | 09:08 AM
I see about those rates, but the car smells so much different now than it did before the ems, i have a test pipe and it has become much more apparent, i havent upped the boost yet. I will get it re-tuned when my 4.25" comes in. thanks
Old Oct 7, 2006 | 09:17 AM
CaptKirk's Avatar
I also agree that its all based on your right foot but yea tuning also has a lot to do with how your car consumes gas.
The lowest I've ever gotten was 14.7 mpg, but it could've been much worse because there was some normal cruising driving involved in that tank. The highest I've ever gotten is 28.6 mpg with pretty much all highway cruising with very little load.
Now granted I don't have 750s, I have 675s but still your mpg shouldn't just suddenly drop like that. I would definitely get it checked out by a tuner to compensate for the upgraded injectors. And also as someone else said, if you have a wideband gauge, monitor your AFRs to see how rich you are running.
I'm very conservatively tuned, and under WOT in boost I see 11-11.5 (I don't have an exact figure cuz Id rather not pay too much attention to the gauge when I'm getting on it like that ). Under normal cruising with little to no load I see 13.2-13.3...
Old Oct 7, 2006 | 06:03 PM
fperra's Avatar
Actually, with a good tune he should be seeing 14.7.
