S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   Fuel pump staging (https://www.s2ki.com/forums/s2000-forced-induction-142/fuel-pump-staging-1195079/)
mys2k3 Jun 21, 2019 03:13 PM
Fuel pump staging
I am running a twin walbro 450 setup and wanted to know how to set up the system so the pumps are staged to come on. Do I have to run a separate wire to the ems to trigger it that way or is it something that is as simple as changing a parameter in the ecu. I am running fullblown’s twin pump hanger setup and had walbro 255’s in it before which both ran at the same time. Thanks.
s2000Junky Jun 21, 2019 03:15 PM
Never heard of staging fuel pumps. Interesting. What is the benefit/necessity of doing this versus running both constant?
mys2k3 Jun 21, 2019 05:56 PM
The Supra guys with double and triple pumps and skylines running high flow twin Bosch pumps have had issues with running too much fuel at idle and fouling up plugs. They’ve also warmed up the fuel some because it is constantly returning unused fuel to the tank. I don’t want to run into this issue running the twin 450’s.
AP1Chief Jun 21, 2019 07:17 PM
Yes my personal car is setup like this, I can help with the EMS tune/setup if you need some.
Mine comes on around 10psi.
riceball777 Jun 21, 2019 10:50 PM
Considering a single walbro 450 supports close to 700whp on e85. Your setup must be making some crazy power. Care to share the setup?
mys2k3 Jun 22, 2019 03:39 AM
AP1Chief- did you have to wire it separately to the ems? I’m running the infinity.
riceball- nothing extreme yet. Fullrace divided manifold with a 6466 and inline pro built head with 2000cc injectors. Looking for a mid to low 9 second run with this setup. Still need to do the trans and rear, t56 with an 8.8.
AP1Chief Jun 22, 2019 06:19 PM
Yes to a output pin, to trigger a relay to turn the second pump on.
soulicious Jul 2, 2019 11:26 AM
I've been running my pumps staged for years with E85. There no point in running two pumps all of the time.
joes sled 2000 Jul 9, 2019 08:52 PM
I run dual Bosch 044 pumps staged on my Integra . The second pump turns on at 1 psi . Running both pumps all the time heats the fuel and puts a high load on the alternator . I do have a stand alone ecu to do this though .
mys2k3 Jul 28, 2019 10:48 AM
What output pin are you guys using on the infinity to trigger the relay? I’m using LS1 for the boost controller.
© 2026 MH Sub I, LLC dba Internet Brands
