S2KI Honda S2000 Forums (https://www.s2ki.com/forums/)
-   S2000 Forced Induction (https://www.s2ki.com/forums/s2000-forced-induction-142/)
-   -   Fuel station solved.Drop in fuel plate. (https://www.s2ki.com/forums/s2000-forced-induction-142/fuel-station-solved-drop-fuel-plate-1190234/)
Kitesurfer s2000 12-09-2018 02:36 AM
Anybody get fuel starvation on left-hand corners or boosted under half a tank?
. I've designed a plate that easily drops inside the fuel tank covering the fuel bowl eliminating any fuel slosh which causes fuel starvation to your engine.
100% cheap fix. No need for expensive external loud pumps.
To find out more please join Boosted s2000 on FB search fuel plate.https://cimg6.ibsrv.net/gimg/www.s2k...353df0280d.jpg
https://cimg7.ibsrv.net/gimg/www.s2k...dc1d7e9b58.jpg
https://cimg8.ibsrv.net/gimg/www.s2k...393e6b5ff0.png
Spoolin 12-09-2018 07:07 AM
Looks like a good idea for fuel slosh, although that's only half the problem. The refill slots at the bottom of the bowl, which is a major problem for big power guys aren't large enough to supply fuel fast enough to the fuel bowl if below a half a tank. The pumps draw too much fuel too fast.
Kitesurfer s2000 12-09-2018 09:30 AM
That's easy :) the slot can be easily made bigger using a large flat screwdriver.
https://cimg5.ibsrv.net/gimg/www.s2k...e996e8b3d.jpeg
Spoolin 12-09-2018 06:10 PM
I've thought about trying to get my tin snips in there and try to trim the slots out larger. I'd use a dremel and grinding tip but excess fumes and all..... LOL
5thgen 12-10-2018 08:18 AM
Looks a lot like the setup from "Road racer".
https://www.s2ki.com/forums/s2000-ra.../#post23694223
soulicious 12-10-2018 12:07 PM
This seems like a lot of work. Why not just get a surge tank?
MARK AUS S2K 12-10-2018 03:21 PM
Surely this is easier to do than a Surge tank?
Kitesurfer s2000 12-10-2018 11:36 PM
20 minutes install time .Haha that's like having a cup of tea in the UK.Plus external pumps are really loud.
soulicious 12-11-2018 12:49 AM
I have a Radium surge tank which has two pumps (staged) mounted inside of it so you barely hear them except when priming. After my original response, I realized that you have to fold your piece to get it into that tank. Good luck.
s2000ellier 12-11-2018 09:33 AM
also should be 20$ not several hundred for an external fuel pump
