Fuel system
Is anyone running an inline fuel filter with e85?
Also so I’m trying to figure out the best option for upgrading the factory lines. -8an feed with stock feed as return or -10an feed and -8an return ? |
Do you need to do upgrade lines to run E85?
Im running -6 off the stock hard line, which is the same size as a -6. The rubber hose with that banjo is the restriction. Everyone says run -8, not sure why though. I'm running -6 making 600hp and I think stewart is running -6 aswell making like 1000hp.
You will basically never need larger than a -06. I am making 1,000 on a single -06 and E90. For a filter, this is your best option on the market:
ID F750 Fuel Filter - Injector Dynamics |
Originally Posted by Quad-Damage
(Post 24605078)
(Post 24605078)
I have been making over 600whp on e85 on stock lines forever. Just got a walbro in take 450 pump and Id 1300cc injectors. |
