greddy brass fitting to oil pan
The fitting in the oil pan is NOT brass.
Just go to any automotive parts store, and a fitting with the same thread size as the oil drain bolt, then, just slip the hose on, and clamp it down.
An even better solution would be to have another fitting welded on, and run a braided line down to the oil pan.
Mine is leaking (only little) from the fitting on the oil pan. Might have to change to the braided like you guys.
