Greddy Oil Return Piping
I have already recieved my new oil pan which I am going to tap for the oil return on the Greddy kit but I am looking for a flange connection. I found this kit on Ebay that would make this easy but I am not sure if the flange will fit. Does anybody have any sugestions or know if this will work.
http://cgi.ebay.com/ebaymotors/_Car-Truck-...d=p4506.c0.m245 Thanks dsddcd |
why not just stick with the oil return style the greddy kit uses? Its very simple and actually allows you to drain the old oil directly from the turbo's housing? I personally think it was a great idea and have had no leaks, from there at least. Freakin oil pressure gauge points on the relocation kit have been my PITA.
I do not like the idea of the oil line hanging down that low and I am not a fan of taking off the oil line every time I change the oil. If I tap the pan the oil will drain from the turbo just the same as it would if I were using Greddy's set up. I have not had any problems with the gauge ports, I used GM's liquid Teflon sealant which I have always had great luck with. As far as leaks go I am having issues with the relocation line set, I have tried to stop the leaks but it has not worked so far. When I replace the oil drain I am going to take all of them apart and start over.
Bump
I would be interested in the solution for that also...
| All times are GMT -8. The time now is 07:45 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
