GTX3584RS dyno numbers are in!
Basic build...
• Garrett GTX3584RS 67/68, T4, twin scroll, 1.06 A/R • Schmuck Built manifold, intercooler, and 3" piping. • AEM Infinity 508 with flex, fuel press, oil press, and o2 sensor. • Stock intake manifold and throttle body. Let me know what you guys would recommend for future upgrades. I'd like to get the TB and IM ported. Car made 390 whp on 93 octane @ 8 psi (wastegate) Made 408 on E30 @ 8 psi Made 416 on E60 @ 8 psi Made 488 on E70 @ 12 psi Made 516 on E70 @ 15 psi Made 565 on E70 @ 17 psi Made 635 on E70 @ 21 psi Tuned by Rob Reinen of Prayoonto Racing (yes, thee Prayoonto Racing!). We still had some 93 octane left in the tank so E70 was as high as we could get it. Should make 650 whp on E85 and 675 whp on E98. Stopping here for now while running stock engine, trans, and rear diff. Running boost by gear vs ethanol content. If I pump in 93 octane at any time, it'll dial the boost back. 1st and 2nd gear get wastegate, 3rd gear gets 17 psi and 4th through 6th get 21 psi. The car hooks flawlessly on the Mickey Thompson 275/40/17 ET Street Rs. Love this setup! Let me know what you think! https://cimg1.ibsrv.net/gimg/www.s2k...410579f7b7.jpg https://cimg3.ibsrv.net/gimg/www.s2k...8320a752dc.jpg https://cimg9.ibsrv.net/gimg/www.s2k...6509363c8c.jpg https://cimg0.ibsrv.net/gimg/www.s2k...a661a18334.jpg |
Thanks for posting this! I've been contemplating hard between this and the 3582. Im pretty surprised at the spool time of this. I'm guessing you went veryyy soft on the IG timing? That's alot of turbo for sub 750hp
The
Originally Posted by Charper732
(Post 24613812)
Nice clean setup man!
Where you at in Indiana? I'm in Sellersburg and Blevins tunes mine. I'm in the middle of a full build right now. |
Originally Posted by wsenefeld
(Post 24613918)
Current setup is temporary until funds are available for a built motor, cd009 trans, and ford 8.8 diff. Another reason as to why i got the infinity 508, I'd eventually like to be running eight 1650cc injectors. I'm hoping the car will break 1,000 whp down the road. Timing depends on the amount of boost and ethanol % but at 21 psi and E85 I've got 20 degrees.
Originally Posted by Spoolin
(Post 24614096)
(Post 24614172)
Care to post your eth IG map? Im more interested in the low-mid timing. Just wondering if the spool time could be increased there. I knew this turbo would be a bit lazier than previous setups ive had. My thought was to use a quickspool valve with a divided housing. Not sure how reliable those things are though
(Post 24614423)
I'm up in Whitestown. You ever go to Greenwood for shenanigans?
(Post 24613728)
Basic build...
Nice numbers! I bet that torque curve is quite favorable for traction and also for drivetrain longevity
Originally Posted by ChefJ
(Post 24615696)
Is this a track only car? If not, what does the good look like with the exhaust dumping there.
Originally Posted by HPC
(Post 24621977)
