Has anyone else been this dumb?
https://cimg6.ibsrv.net/gimg/www.s2k...02c736ba64.jpg
Was clocking my sandwich plate to make room for a new oil pressure sensor and I guess I over-torqued the 38mm banjo bolt. It didn't sheer off until I started the car and was letting it warm up (could have been worse and happened while driving). Totally my fault, but I'm surprised at how little thread engagement the banjo bolt has....there is about 3/4" of threads still left in the block. https://cimg1.ibsrv.net/gimg/www.s2k...b7b4e79475.jpg https://cimg3.ibsrv.net/gimg/www.s2k...95e0577e42.jpg https://cimg7.ibsrv.net/gimg/www.s2k...8b8a2881ac.jpg |
It has happened before..... But in your defense, it doesn't look like there was enough thread length on the remote oil filter/cooler adapter bolt. So it doesn't look like the part was designed properly.
bro.....thats a QUICK way to trash a block. Did you use the longer threaded piece from the accord?
Originally Posted by spdracerut
(Post 24564290)
Originally Posted by Charper732
(Post 24564291)
90015-PH1-013 that's the part number...its like $5
You can likely make this all work again without replacing the block. You will want to have a custom stud made that is longer, and you might need to tap the hole if it is tapered (I do not think it is).
a machine shop will be able to do this for you. |
Originally Posted by RAIN H8R
(Post 24564502)
https://cimg8.ibsrv.net/gimg/www.s2k...f36ec7fe40.jpg
Got my custom bolt back from the shop...it should engage all the remaining threads left in the block |
Nice save!
It could be the picture but that looks like an excessive amount of silicone on the front cover, I would be concerned if it were on the inside of the cover too... |
