head gasket
hi im about to boost my cr and have a couple questions for you guys, one are the head gasket and studs the same on the f20 and f22? and also what is your guys opinion on a 3mm head gasket? i already have the cometic one and im looking to top off at about 500 whp with a gt30 turbo and inline pro log mani, just need a few more parts to start putting it on. Any opinions would be great and also any ideas on ecu's would help me out thanks guys!
yes get a 3mm (or even bigger!) headgasket
for tuning, just get a chip off ebay
that is the perfect manifold for your power goal
studs are the same, i would imagine the head gasket is too
good luck!
good luck!
I have a 3mm HG for sale. You will have to replace the outer layers but its for a bomb price! The 3mm HG works fine for power under 500 and you can make a lot of power on pump gas with it and the log mani. If you don't run the 3mm on that log manifold, you'll only make like 380-400hp.
if u want 500 on pump gas upgrade ur manifold, i mean if ur dead set on making 500 with a log then throw the 3mm hg in, but it will blow, u will replace it, it will blow again..
This^^
Take a look at the Real Street thread, they were on stock gasket, head bolts ect ect @ 700+ whp
Mani is going to hold you back more than compression ratio at this point.
